Highlighted
How much data can you tether on an unlimted 5G plan.
I've pre ordered a S20 ultra, and going to get a 5G sim card I currently have a 4G plan.
2 questions.
1. Is there a limit on tethering 5g as I would like to tether to my xbox one and android box
2. Will I require a 5g sim or can the simply upgrade my plan to 5g and I can keep the same sim.
First post, thanks in advance.
Highlighted
Solution
Re: How much data can you tether on an unlimted 5G plan.
  1. You may use up to 1 TB data & tether no more than 11 devices on an unlimited plan to keep to EE's requirement of solely for personal use.
  2. Same goes for 4G & 5G plans. You may upgrade your 4G SIM plan to a 5G plan.
Highlighted
by Ace Contributor
Hi, @Seanbcfc1 You can use unlimited hotspot of your phone as long as it for your personal use.
 Please read below.
https://community.ee.co.uk/t5/Pay-monthly/Introducing-our-new-unlimited-plans/td-p/799946
Highlighted
Solution
Recent solutions
