by morgandeano
Can I use Mi 5G device with an EE SIM ?
I was wondering if I buy this device and put my 4G EE Sim in it will I get 5G services ?
https://mobile.mi.com/uk/mix-3-5g/
Solution
Re: Can I use Mi 5G device with an EE SIM ?
Hi @morgandeano
Welcome to the community.
You'll be able to use 5G on your existing SIM card, as long as you change to a 5G Smart Plan and a 5G enabled device.
Solution
Hi @morgandeano
@morgandeano   Just to add you’ll need to be in a 5G area to receive 5G and at present there is only 6 cities that have 5G see HERE
