Highlighted
by Investigator
5g connectivity
I upgraded my phone to Samsung ultra s20 and it shows a 5g connection at the top of the phone but I'm still only getting 4g speeds when I ran a speed test app it showed it was connected to lte and not 5g as the phone stated any idea how I can get the correct data performance on my phone
Highlighted
by Brilliant Contributor
Solution
Re: 5g connectivity
Are you in a 5G enabled area?
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
12 REPLIES 12
Highlighted
Solution
Re: 5g connectivity
Highlighted
by Investigator
Re: 5g connectivity
Yes in North shields and I'm on a 5g plan
Highlighted
Re: 5g connectivity
What speeds are you getting
Highlighted
by Investigator
Re: 5g connectivity
The highest I have had where I live is 23mb but its usually between 8 and 12mb had 5g connectionScreenshot_20200509-225126_Speedtest.jpg
once when I was outside and about 400 meters from my house
Highlighted
Re: 5g connectivity
I have just out north north s into the coverage checker and it states that you will get 5G outdoors.
Highlighted
by Ace Contributor
Re: 5g connectivity
Some speedtest apps don't show 5G correctly, it's the speed that matters, not the icon. As long as it says 5G on your phone then you're using 5G.
Highlighted
by Investigator
Re: 5g connectivity
I did another speed test it shows 5g in my house at the top of the screen but says I'm using lte in results I have highlighted it showing the one time it shows 5g on the speed test so I known it shows the difference
Highlighted
by Ace Contributor
Re: 5g connectivity
Hi @Uksmiler (cc @chistery and @BrendonH),
The 5G icon in the screenshots is not coloured in which means you are not actually connected to the 5G bearer. This is why your speeds are as they are.
Thanks,
Peter
Highlighted
by Investigator
Re: 5g connectivity
I went around 400 meters away from my house where it starts to connect to 5g speeds and the colour of the 5g symbol doesn't change its like around my house its showing 5g but connecting to 4g
Highlighted
by Ace Contributor
Re: 5g connectivity
Hi @Uksmiler,
In your latest screenshot, the 5G icon is coloured in and you are using 5G.
Highlighted
by Investigator
Re: 5g connectivity
So I am right even though it shows 5g signal because its not coloured in its reverting to 4g so why is it doing this and how can I keep it on 5g
Highlighted
by Ace Contributor
Re: 5g connectivity
It's reverting to 4G because the 5G bearer doesn't meet the radio quality requirements to be added. It's a case of waiting for 5G deployment to spread.
Recent solutions
