Highlighted
New Member
5g bands ?
I have bought s20 u Hong Kong
Like to know it work on ee ?
5G Sub-6 FDD: N1(2100)
5G Sub-6 TDD: N78(3500),N79(4500)
Highlighted
by Ace Contributor
Solution
Re: 5g bands ?
Hi @Jack5g2468,
Band wise that supports EE's 5G (N78).
However, as it has not been purchased from the UK, it may not have the correct ROM for 5G to be enabled.
Kind regards,
Peter
Highlighted
Re: 5g bands ?
Highlighted
by Ace Contributor
Solution
Re: 5g bands ?
Hi @Jack5g2468,
Kind regards,
Peter
Recent solutions
