Highlighted
by Established Contributor
5G Masts Location - Trial
Hi all,
  1. Is there anyway apart from contacting customer care to see in a map 5G enabled masts? I am interested in LS98DX - Leeds.
  2. What is the best way to have a trial (one month contract for example) of the EE 5G network?
Thanks,
Ioannis
Highlighted
by Brilliant Contributor
Solution
Re: 5G Masts Location - Trial
I didnt suggest a PAYG sim
I told you to get a 30 day sim only sim which does include 5G access.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
Highlighted
Get a sim only 5G tariff for 30 days to test it out but you'll need your own 5G enabled phone.
Highlighted
Pay as You Go SIMs they don't include access to 5G.
I will need to go down the root of ordering a 12-month sim online and then request to break the contract within 14 days from the delivery.
Highlighted
Solution
Recent solutions
