Highlighted
by Investigator
why won’t EE connect to a VPN
My EE WiFi connects fine to the internet but not to my work drive which is VPN. I’ve changed EE account from IPV6 to IPV4 as directed by EE technical dept but it hasn’t helped. Help!?!?
Highlighted
Re: why won’t EE connect to a VPN
Hi @Lucille,
Welcome back to the community.
Have you spoken to your IT department at work to see if they can help?
Highlighted
by Investigator
Hi yes I have at length. It is not a work issue. I can connect from home via my neighbours WiFi no problem. I’ve spoken to many EE technical staff as well...
Sent from my iPhone
Highlighted
Hi @Lucille,
Do you know which VPN client your company uses and if it is IPv6 compatible?
Highlighted
by Investigator
Hi no it is only IPV4 compatible so I changed my EE from 6 to 4 and it made no difference.
Sent from my iPhone
Highlighted
Hi @Lucille,
Have your IT department contacted your VPN provider to see if they have a newer software version that is IPv6 compatible?
