by AntheaChang Contributor
my4Gee isn't working
I have been using my 4GEE (September)since I have buy the plan. It has a very good connection and it's easy to use so far so good . However,starting from yesterday the wifi egg start flashing (blue light- everything flash altogether) and I can't reset or reboot or off or on the device. Also the account never shows your device 4GE, it now shows iPad mini. I have an iPad I have put the sim of the egg inside yesterday night in prefer to get wifi but I have got out of it already. What should I do now?
Solution
Re: my4Gee isn't working
I have brought to the EE shop and they have checked and that's a liquid damage
7 REPLIES 7
EE Employee
Hi and welcome to the Community @AntheaChang
So I can try and assist, please may I know what type of device it is that you are using?
Many thanks,
Lee
It's an 4GEE Mini
Hi @AntheaChang,
Please can you follow the instructions below to reset your device and let us know if that fixes the problem for you.
Perform master reset via hardware:
  1. Remove the bumper to uncover the Reset button.
  2. Using a paperclip or pen, press and hold the Reset button for approximately 5 seconds.
  3. The device will restart automatically.
You can find more information on our help pages.
Solution
Good morning @AntherChang
Thanks for coming back to community 🙂
In terms of the liquid damage, how best did they advise you to proceed?
Richard
They said I can either go out and fix it by myself or buy a £9 monthly plan with a new device and also a shared sim with my phone because they can't just sell a machine.
EE Employee
Morning @AntheaChang
You can purchase a pay as you go mobile broadband device on our website.
See the EE Shop for what's available.
May Thanks,
Karen. Smiley Happy
