by Nigel1964
how do i connect arlo pro security via ethernet to 4gee hub
I have an arlo pro security system that requires internet connection but it needs ethernet connection to hub. I have a sky BB hub that it used to work through.
Any ideas please.
Re: how do i connect arlo pro security via ethernet to 4gee hub
Hi @Nigel1964
This is EE, not Sky community
Connect via power line adapters to your hub.
If that device can't connect by WiFi you're gonna need a mobile BB router that has Ethernet ports, like the 4GEE Home Router.
by Nigel1964
Thank you for your answer, Im aware its EE as ive bought the 4gee yellow and black wifi. what i was saying is that i used the arlo through the sky hub but finished the contract. I also thought i might be able to utilize it?
I have 2 tp-tl-pa4010 and a tp wifi av500. ive tried a few way connecting them but no luck
The point was that we can't give you advice about using a Sky router. If you can find a way to connect it to the 4GEE Wifi router so well & good.
Your device worked with the Sky router in the past cuz it has Ethernet ports; the 4GEE Wifi router you bought doesn't.
Hi @Nigel1964
The yellow and black router won't work as it's only very limited. You want the white one, as it comes with lan ports.
https://shop.ee.co.uk/dongles/pay-as-you-go-mobile-broadband/4gee-router-payg/details
The above is PAYG but you can get it on pay monthly contract.
