by jojobown
how.do i change my ee wifi password
how do i change my ee wifi password without a computer or laptop only have a android phone
Solution
Re: how.do i change my ee wifi password
@jojobown   You need to login to the router.  There should be a URL address underneath the device.  With a browser on your phone type in that address and you’ll need to enter the password and user name both are admin.  You can then change the router WiFi password.
Solution
