by carmont
how do I find my pppoe settings for 4G Router
I am trying to setup my IP Camera on my 4G Router how do i find the PPPOE settings?
Re: how do I find my pppoe settings for 4G Router
Mobile routers don't have PPPoE settings. They are not connecting to the WAN over Ethernet. Maybe you are thinking of APN (or Profile) for mobile connections. IP Cameras don't need either as they only connect directly to the router, not the Net. To access them all you need to refer to is their IP addy & port no.
Are you connecting the IP Camera to the router by Ethernet or WiFi?
What model IP Camera is it?
by carmont
Hi
it is connected via Ethernet the model is Rimax 7100
You connect to it by the IP addy it is assigned by the router & the port no. it is set to in its settings, of the form 192.168.1.10:80 . It would be well to fix its IP, either in the router or the camera itself.
