by ryanmustard21 Investigator
connect new phone to mobile boardband
Trying to connect new phone to mobile boardband, getting authentication problem and won't connect
6 REPLIES 6
Re: connect new phone to mobile boardband
Afternoon @ryanmustard21
Are you trying to connect to the WiFi?
What phone are you using?
Yes it worked fine then I ran out of data and just got it back but got upgrade phone Sony zx2.
The portable unit I noticed isn't actually lighting up properly, the little green signal dots aren't on but one is red even in places I've had signal before.
Can you connect any other devices to it, @ryanmustard21?
I haven't tired but I can tonight
I've tired to connect my xbox one to it still no luck
Thanks for trying that @ryanmustard21
I'm going to send you a private message to get some more information from you.
Please have a look and reply.
