by paulfenn
Yellow box
Hi
Any ideas what GHz the mini wifi runs on, as need to set up a camera.
Tech section cant answer it!!
Many thanks
Paul
Solution
Re: Yellow box
2.4
Solution
Re: Yellow box
2.4
Re: Yellow box
Good morning @paulfenn
Thanks for coming to see us in community 🙂
Has the advice kindly given by @Northerner answered your question?
Richard
by paulfenn
Re: Yellow box
Thanks for the reply, very helpfull and cleared issue up for me.
Paul
by Ace Contributor
Re: Yellow box
Hello @paulfenn the 4GEE Wi-Fi device supports either the 2.4ghz or 5ghz bands.
To choose which band you want to use download the Alcatel Link app from your devices App Store then navigate to Wi-Fi settings:
