by Matty2k_81
WiFi mini
I’ve been given a ee WiFi mini, can I use any EE nano sim or does it have to be a data one?
Solution
Re: WiFi mini
  • Phone SIMs are intended for mobile phones & usually have loads of call mins & texts but only moderate data.
  • Data SIMs are designed for mobile BB devices & have loads of data but no call mins or texts.
7 REPLIES 7
Re: WiFi mini
You can use any EE SIM in it that fits. Obviously a phone SIM will have less data than a data SIM.
by Matty2k_81
Re: WiFi mini
I’ve seen a sim only plan with 40g data, will this be slow?
Re: WiFi mini
All EE SIMs run at 4G speeds.
by Matty2k_81
Re: WiFi mini
What’s the difference between a phone sim and data sim?
Solution
Re: WiFi mini
by Matty2k_81
Re: WiFi mini
Ee currently doing 40gb with calls/text sim only for £25 a month, obviously I don’t need calls/texts. This seems better deal than data only sims available. Thanks for your help.
Re: WiFi mini
Yes, it's on special offer. You would be able to use the texts from an EE WiFi Mini but not the call. Texts could come in useful.
Thanks! You're welcome :)! Glad I could be of assistance.
