by Jackc1994 Investigator
Why is my network down? I can only use internet using WiFi?
My bill has been paid I have 11GB left why have you cut me off?
Re: Why is my network down? I can only use internet using WiFi?
@Jackc1994   Have you been cut off or is there a network issue in your area ?  Have a look at THIS.
if you can use WiFi calling give it a go because if it works you haven’t been cut off at all.
Good Morning @Jackc1994
I am sorry to hear this is happening.
Have you been able to check the Network Checker which was advised by @Chris_B?
Speak soon,
Katie 🙂
Yes I checked last night and also today and I can’t use my phone without WiFi?
Why is this.
I live in Bromley no signal
I work in paddington no signal?
Sent from my iPhone
Hi
Yes I have tried and I am still unable to use my data I live in bromley and working in paddington and can’t use it anywhere?
Please advise
Sent from my iPhone
Hi @Jackc1994.
Did it show any known problems?
Are you able to try your SIM in another device and see if this issue continues?
Speak soon,
Katie 🙂
