by Beky92 Contributor
Why can't I connect to the tube WiFi?
For some reason I can't connect to the underground WiFi and I don't understand why! Can anyone help with this?
Solution
Re: Why can't I connect to the tube WiFi?
Morning @Beky92
Thanks for coming back to us.
Can you try and use the EE- WIFi-Auto Hotspot option as below:
Once underground, just turn on your WiFi and select EE WiFi-Auto from the list of available networks.
Then select the ‘access method’ as EAP, and ‘EAP method’ as SIM.
Let me know if this works for you 🙂
17 REPLIES 17
EE Employee
Hi and welcome to the community @Beky92
Have you been able to connect to the London underground WIFI previously?
Many thanks,
Lee
I've never been able to connect.
I've tried several times to send a text to 9527 but they never send me the password to use to log in to Virgin!
Hi @Becky92
What kind of phone are you using?
What kind of error do you get back?
Richard
Hi @Richard_C
It doesn't give me any error, it just doesn't reply to me at all, but when I sent the wrong text (I wrote EE WiFi, with the space in between) it said that it didn't recognise the code, so the service works, it just never replies to me when I text the right thing!
I have a Samsung s7 edge
Thank you for your help
Solution
Morning @Beky92
Thank you very much for your help! It worked! Smiley Very Happy
Great news @Beky92
No problem at all 🙂
Have a great day and come back anytime.
by Danniem4 Investigator
When I select the WiFi it asks me to log in? If I use my EE login it doesn’t work?
Hi @Danniem4
Are you trying to connect to 'EE WiFi-Auto'?
Find more information on WiFi on the London Underground >
Yes
Hi @Danniem4
Thanks for trying this.
What happens when you follow the below steps?
I’m not seeing an access mode or anything it just asks me to log in with a
username and password
Hi @Danniem4
Thanks for coming back to me.
Have you tried texting EEWIFI to 9527, and follow the instructions within the text?
Leanne 🙂
I’ll try that now thank you
Let me know how you get on @Danniem4
by west4
New Member
Hi my phone connects easily to EE wifi auto on the London underground. I'd like to be able to connect my ipad too - but it's wifi only and doesn't have a Sim. Is this possible?
Hi @west4,
Welcome to the EE Community.
Sorry, you wouldn't be able to use your EE WiFi on the underground with your iPad.
