by JOJOBB Investigator
Using EE unlimited sim in Huawei b535. Sonos, Alexa, Samsung smart tv wont work
I recently purchased a Huawei b535 after reading excellent reviews, along with EE unlimited 4 g sim, as I’m in a rubbish area with slower fibre than copper, approx 4-9 mbps.
The speed isn’t an issue, all our phones connect fine, as do iPads, and MacBooks. However it won’t even connect wired to our Samsung smart tv. Our Sonos, Alexa’s, and robot vacuum will not connect wirelessly. Any ideas? EE issue or router?
Solution
Re: Using EE unlimited sim in Huawei b535. Sonos, Alexa, Samsung smart tv wont w
Fixed it!
In network settings there was an option of EE or auto. My husband selected auto and it all works perfectly!
9 REPLIES 9
Hi and welcome to the community, @JOJOBB
Are you given any error messages when you try to connect, or are the devices just not finding the router?
Hi Chris,
no error message, just unable to find the router. Keeps searching but just doesn’t find anything.
The Tv shows an image of the Tv-router-internet. it shows it’s connected to the router but says no signal to the router, which is bizarre as phones, macs etc are connected.
Thanks.
OK, thanks @JOJOBB
I recommend speaking to our Tech Gurus, to see if there's anything they can do to help.
Also, @XRaySpeX is brilliant with things like this, he may be able to offer some help too.
Chris 🙂
Is this Huawei b535 router one of EE's device under a diff name?
Does it have 2 wireless bands, 2.4 & 5 GHz? If so, connect your TV to the 2.4 GHz band
It does have both, I’ll have to try figure out how to manually change between the two. Thanks
Don't they have diff SSIDs? Just select the TV to connect to the 2.4 GHz band.
Tried 2.4ghz, still won’t work.
Solution
Fixed it!
Funny how it connected some devices but not others. That setting would apply to all connections.
Recent solutions
