by Sparty
Unlocked mobile broadband device problem
Hello
New poster here.
I have successfully unlocked my out of contract mobile broadband device - little yellow box - and now it won't connect with the new sim card. (not EE)
I can connect devices to it but it won't bring up any web pages. On the 168/192 page everything looks like it's ok except the connection dot is black and when I try to connect it says connecting then goes back to disconnected.
Any ideas?
Many thanks
Sparty
7 REPLIES 7
Re: Unlocked mobile broadband device problem
Hi @Sparty
Those devices only connect to a limited number of network frequencies so it maybe your new network isn't compatible with the device.
Which network are you trying to use?
Are you trying to use it abroad? If so, where?
by Sparty
Hi Northerner!
Thanks for the reply.
A Virgin sim I have already that has unlimited data so it would be great if I could use it!
It's a 3G sim but I was told by EE tech support that it should work.
by Sparty
Hi XraySpex
Leicestershire ... 🙂
by Profile closed
Not applicable
You will probably need to manually create a new APN profile within the router settings as MBB devices generally don’t pick up their APN settings automatically from the SIM card.
You will need to know what he Virgn APN settings are and then log onto your MBB device and create a new APN profile specifically for the Virgin SIM.
Edit, here are Virgin Mobile UK APN settings you need to create a new profile:
Internet APN
Dial Number *99# APN: goto.virginmobile.uk Authentication Type: CHAP Leave all other options blank/Not set
  1. Log into your MMB devcie by surfing to 192.168.1.1
  2. Click on 'Settings' enter your username & password (the factory defualt for both these are admin (unless you have changed these yourself)
  3. Click on the  'Connection' tab then click 'Profile Management'
  4. Click 'New'
  5. Enter the details as above then click 'Save' and then click 'Set Default'
by Sparty
Hi @Profile closed
Thanks for that. * edit - I hadn't seen your edit when I wrote this reply! Thanks again.
I can see where I need to do this and the APN stuff is available online but the profile requires a 'dial number' and I have no idea what this is! Can't seem to find much reference to these ...
The existing one for the EE sim is *99#
I'm baffled!
by Profile closed
Not applicable
Use the same one as for EE.  That code will work for any provider.
