by 987s
Stop auto-join of public EE Wifi
EE has a number of areas with free wifi - stations, TfL locations on the tube network and others.   I never allow any of my devices to join a wifi network whose security isn't known to me, so I block this.
But, whenever I get a carrier settings update, EE wifi is turned back on.   This is really annoying, as I have no wish to join something that is fundamentally insecure, as most public wifi is.
Has anyone found a way to block this permanently, such that a carrier settings update doesn't re-enable it??
Re: Stop auto-join of public EE Wifi
@987s  Turning off WiFi or blocking them is your only option,  and turning off WiFi will help with battery life as it’s not searching for a network to join.
by 987s
Thanks, thought that might be the case.
Annoying, as I use wifi at home and in the office, so having to switch off to block auto-join of a network that I've already asked my phone not to join is frustrating!
