by jaffacakes
Signal randomly cuts out
I get about 40mb speed. Almost like clockwork, every 30mins or so the little EE4G device stops working. No matter how long I wait. Every time I need to reset it and its fine again.
Very challenging as I'm trying to do conference calls but always drop off.
Please advise.
8 REPLIES 8
Re: Signal randomly cuts out
Which MBB device is it?
by jaffacakes
The 4GEE WiFi Mini
They seem to go to sleep every 30 mins to conserve battery.
Are you running it with the USB plugged into a PC or charger? That should keep it alive.
EE Employee
hi @jaffacakes and welcome to the community.
Please try the advice given by @XRaySpeX and let us know how you get on.
Many thanks,
Lee
by jaffacakes
Yup I always have it plugged in and makes no difference. When it completely cuts out the little light still flashes. But becomes non-responsive so I need to hold down the on/off button a while (10 secs)
EE Employee
Hi @jaffacakes
Please, can I get you to try and master reset the device to see if that helps?
Many thanks,
Lee
by jaffacakes
I tried that earlier but still the same issue every 30mins or so.
EE Employee
Hi @jaffacakes
I would recommend speaking to our technical team who will be able to run a diagnostic to see if there is anything we can do to help.
Many thanks,
Lee
