by Apehanger Investigator
Secure Connection Failed
Unable to log in to my bank. Keep getting the above message.
It is not the fault of my bank because I still have Plusnet for a few days and when I logged into that I had no trouble.
I tried online chat with  someone called ABHISHEK and he was no help whatsoever. He even closed the window when I explained it was an EE problem not my bank.
Anyone had similar problem as I only have a couple more days with Plusnet.
TIA
Solution
Re: Secure Connection Failed
Well,
I have just reset my router and ....
Success 🤗
I changed my content lock a few days ago and was able to get onto my forums without resetting?
Anyway, it works!
Thank you all for your help. Now to pay some bills 🙄
9 REPLIES 9
What device & network are you doing this on? Is this a mobile BB router?
Hi.
I'm using a laptop, 4GEE Wifi, via 4GEE Router
by Ace Contributor
Which bank is it? Do you have content lock on or off?
Santander.
How do you check content Lock on/off please
by Ace Contributor
Santander works for me on EE.
Content lock instructions can be found here.
It is on 'Full Access'
Solution
Well,
Success 🤗
Anyway, it works!
by Ace Contributor
Glad it's sorted, @Apehanger. Enjoy the rest of the weekend!
Thank you once again for your help.
