Highlighted
by Investigator
Resetting 4GEE Router
Hi folks,
Can you tell me, if I reset my 4GEE Router, will it connect up to the internet again and still work OK?
Thanks.
Highlighted
Solution
Re: Resetting 4GEE Router
@Matty5   If you reset it it should connect.  Your only doing a hard reset of the device.
Highlighted
Solution
Highlighted
by Investigator
Thanks Chris_B. My settings were changed (I was slow changing admin creds) and it doesn't perform as well now, so I want to reset it to restore them.
Highlighted
Hi there @Matty5
Let us know how you get on after resetting the 4GEE Router, if you have any problems connecting, we will certainly see what we can do to help 🙂
Thanks 🙂
Highlighted
by Investigator
Thanks Chris_B and Leanne_T, that worked a treat 😊
Highlighted
