by Stucardy Investigator
Reset mini wifi
I have a mini WiFi, which won't switch off.
There are no lights on the display, although the EE logo goes on and off.
Any suggestions?
8 REPLIES 8
by Ace Contributor
Re: Reset mini wifi
Hello @Stucardy you should be able to stick a pin in the little hole next to the charging point to reset it. Failing that let it run down then try it again when it has recharged. 🙂
Re: Reset mini wifi
Thanks, will give it a go
by Ace Contributor
Re: Reset mini wifi
Hopefully it lives to see another day. 🙂
Re: Reset mini wifi
Welcome to the community, @Stucardy. 🙂
How did you get on?
Look forward to hearing from you.
Re: Reset mini wifi
Hi Chris
I tried pressing the reset button and nothing happened. I left it over night without power, but the EE logo is still flashing. Any other suggestions?
Stuart
Re: Reset mini wifi
Could you try the same thing with the power source connected, @Stucardy?
Re: Reset mini wifi
Still no joy I'm afraid. The charge lights don't illuminate either
Re: Reset mini wifi
Thanks for trying @Stucardy.
I recommend getting in contact with our technical support team.
They will do their best to help you further with this.
Please let us know what happens.
