by joefife
Overage - 200GB plan
Is it possible to buy two lots of the same price plan for one device?
In this case, where around 350GB a month will be used, what's the cheapest way of getting the extra 150GB of data?
Re: Overage - 200GB plan
Hi @joefife
Thanks for coming to community 🙂
It's not possible to combine plans.
Maybe as an idea you could run the two SIM cards and when one runs out then insert the other.
Hope that helps.
Thank you
Richard
by martineecom Investigator
An EE reseller called Pinnacom Ltd does totally unlimited EE data only SIM cards.  You basically pay per GB used. Call them to get very high data services on EE.
