by sumed-m Established Contributor
Netgear nighthawk m1
Hi. The Netgear Nighthawk M1 is one of the fastest LTE device. Could you please share the specifications of it. EG. The Ethernet port, is it a 1gbps port? The usb c version(2.0 or 3.1). And other features. I’ve been searching on ee website but couldn’t find anything. Thanks in advance.
by Brilliant Contributor
Solution
Re: Netgear nighthawk m1
@sumed-m, I have done the work for you by doing a search and as you can see from the link, you can see what ports etc there are:
http://www.netgear.com.au/home/products/mobile-broadband/mobilerouters/M1.aspx#tab-techspecs
8 REPLIES 8
Solution
And the data sheet.
http://www.netgear.co.uk/landings/nighthawk-mr1100-mobile-router/Telstra_MR1100-Datasheet.pdf
netgear nighthawk m1 Ethernet port
There is an Ethernet port on the netgear m1. Is it a gigabit port or 100mbit only? Could someone Please let me know. Thanks in advance
Re: netgear nighthawk m1 Ethernet port
@sumed-m
http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf
Page 10
Ethernet port.You can connect an Ethernet device to this port and you can offload your mobile Internet data.The Ethernet connection speed is about 500 Mbps.
Afraid I can't find that documented anywhere. Suggest you try Netgear support.
Ah, that must be a Gigabit port allowing 500 Megabits each way.
@Northerner Thank you very much. Appreciate that
EE Employee
I'm glad you got the information you needed @sumed-m
Many thanks,
Lee
