by graemerwaugh Investigator
Netgear nighthawk Battery issues?
After only a few months it seems the battery in the Nighthawk is no longer able to hold much charge. Once charged it lasts only maybe 1hour (using both 2.4 and 5).
 Does anyone else have experience of this? seems rather poor for a "mobile" router
Thanks in advance
Graeme
9 REPLIES 9
Re: Netgear nighthawk Battery issues?
Hi @graemerwaugh,
Welcome to the EE Community.
I'm sorry to hear your Nighthawk battery life has deteriorated.
Have you spoken to technical support?
Yes, I have spoken with them, not really of much use if I'm honest.
They stated the battery runs down more when you use it more! Then said I should monitor the battery life. (which I already have otherwise I wouldn't be contacting them).
I explained my benchmark which is, Device when new battery life = approx 24hrs  with approximately the same the data volumes as now. Battery life now = 1hr and unit continue to go into orange blinking more and dropping the connection. But apparently, I need to measure it more.  Even though measuring the actual life of the battery on its own tells you absolutely nothing without assumptions about the computed volume passing through the router.
Not the most satisfactory outcome
EE Community Team
Hi @graemerwaugh,
Did the guys at technical support complete any diagnostics on the device for you?
Do you know when you purchased the Nighthawk? And was this part of a pay monthly contract?
Alex
Hi Alex,
No,  they didn't complete any diagnostics
Purchased in Jan 2018 I think as part of a pay monthly contract yes
EE Community Team
Hi @graemerwaugh,
You can run through a quick check list on Device Repair here to see if there is anything else you could try on the device before getting back in touch with our tech guys.
This page also talks you through options to Booking a Repair
Our customer service team will be able to advise you of all of the options available depending on your account settings.
Thanks, Alex_S
Fix my Device, unfortunately, has very little data around the Nighthawk so didn't really solve the problem.
EE Community Team
Hi @graemerwaugh,
I'm sorry you couldn't find what you needed from the help page I suggested.
Before you book in for a repair I would get in touch with our tech team for further investigation. They will be able to give the best options moving forward.
Both our  teams are open from 8am today 🙂
Alex
by kevdyas85 Established Contributor
I’ve had the same issues with my router. It doesn’t fully charge to 100% and battery life has become very poor. Lots of similar experiences on the Netgear community.
Hi there @kevdyas85
Have you spoken to our technical support team, so they can help you get this looked into?
Thanks, Leanne.
