by Lunny
(Mywifi)
Hi there,
i have reset my WiFi top up box and have lost the keep me card and there’s no label what so ever on the little box ?? I know the admin but not the actual original password
Re: (Mywifi)
Hi @Lunny
It's useless then.
Is this the yellow one?
Re: (Mywifi)
All is not lost!
Both the admin user & pwd were originally "admin". If you've forgotten the WiFi pwd you can login at http://192.168.1.1 as "admin"/"admin" & go to Wireless section & you'll see the WiFi pwd in clear.
If you've ever changed the admin pwd you'll need to factory reset the device by pushing a pin the reset hole for about 10 secs & the admin pwd will default back to "admin"
by Lunny
Re: (Mywifi)
Hi, you have to be connected in order to get into the 192.168.1.1 in first place it’s that password I need to recover ?
Sent from my iPhone
Re: (Mywifi)
You connect, not by WiFi, but by the USB cable to a PC. It installs a Web Connection program on the PC which creates another Ethernet port to the PC.
Re: (Mywifi)
Hi @Lunny,
Welcome to the EE Community.
Did @XRaySpeX's advice help?
