by nukleopatra Contributor
My huawei device is not working
Hi my wifi device has stopped working. There is no internet connection
by Profile closed
Not applicable
Re: My huawei device is not working
Hi, @nukleopatra,
Try re-starting you device!
This will perform a mini re-boot!
Regards
mAh8v
Good Afternoon @nukleopatra
Have you been able to follow the advice from @Profile closed?
Are you able to send texts and make calls?
Katie 🙂
by Profile closed
Not applicable
Hi, @nukleopatra,
Make sure your Huawei device has the internet access enabled in you device, you can check this in the settings menu under "networks" ok! 😊
Regards
mAh8v
