by Nothingbutnet
My 4g Wifi mini has stopped charging.
I tried different charges but the same outcome it ain't charging.
Solution
Re: My 4g Wifi mini has stopped charging.
Good Morning @Nothingbutnet.
Welcome to the community 🙂
Great advice from @Northerner.
You will usually find the reset button on the back of the device or next to the SIM slot, and you will need a pin to press the button.
Our technical support team will be happy to help if you're still getting trouble.
Jon
Hi @Nothingbutnet
Try resetting it via the rest button, then try again.
If not then it's dead so take it into EE or call EE on 150.
by Nothingbutnet
It worked I rested it and it started charging thanks for the help.
Solution
Jon
by Cragrat
New Member
I have used the reset button and held for 10 seconds and no joy.  It was working fine yesterday - it is now 2 years old and the charge light does not come flashing as it usually does. Blank scree.
Hi there @Cragrat
Thanks for coming here.
What device do you have?
Speak soon.
Leanne 🙂
