by London-40 Established Contributor
Mobile data
I have used all my data for this month and now i just check in the app it is showing that i have 10 gb data to use i dont know what to do
by Brilliant Contributor
Solution
Re: Mobile data
If it says you got 10gn left are you able to use data?
On EE if you run out it wont let you use it
Itll automatically direct you to buy more.
So if it's still working then either your allowances have refreshed or you have bought more data.
Solution
Re: Mobile data
