24-05-2020 05:39 PM
I purchased a 4GEE mobile broadband for my parents to use with a facebook portal and i want to know How can I check the baLance and top up data if I don't have the device.
24-05-2020 06:32 PM
Is the contract in your name? If so it should appear as another number on: https://myaccount.ee.co.uk/ or on the My EE mobile app.
If it's not under your name, the easiest way to check would be to go to: http://add-on.ee.co.uk/ on any device that is connected to the 4GEE device, which should the display the usage statistics and provide an option to buy more data if needed.
24-05-2020 07:27 PM
You can see the balances by registering a MyEE a/c for it.
You could try using Fast Top Up to top it up.
