by PThax1967
New Member
Mini wifi not accepting password
My portable EE wifi is not accepting my passsword
Re: Mini wifi not accepting password
@PThax1967: Which pwd? Your WiFi pwd?
You can connect it to a PC by USB. It will then invite you to install its Web Connection s/ware. You can then connect from the PC to http://192.168.1.1 as if it were Ethernet. You may then login to it as "admin"/"admin". You will then see the WiFi pwd in clear in its WiFi Settings. You don't need to be on WiFi to do this.
EE Employee
Hi @PThax1967 and welcome to the community.
Please follow the brilliant advice given above by @XRaySpeX.
Let us know how you get on.
Many thanks,
Lee
