by Debcantrill Investigator
Mini Wi-Fi not in usa
Hi
I was told me mini Wi-Fi would work in the usa which was the main reason i got it. Arrived in usa yesterday and it doesnt.
When i turn it on it has a red light instead of green on the signal lights.  Any help would be appreciated.
Solution
Re: Mini Wi-Fi not in usa
Hi @Debcantrill
@XRaySpeX is correct it only works in the EU. You can take the SIM out and use it in a phone/tablet and allow the mobile hotspot option.
14 REPLIES 14
@Debcantrill: I understand these MBB router are only designed to work in Europe with our mobile bands.
Solution
Hi @Debcantrill
Hi @Debcantrill,
Welcome to the EE Community.
I'm going to ask our technical team to check this device will work in the USA.
In the meantime, can you please check roaming is activated in My EE? Just select 'Manage device' from the menu to check.
Is this device on PAYG?
No it is not
Hi
I have checked and the roamimg is activated
Read more
Did you buy a roaming data add-on for the US? Your UK allowances are not valid there.
@XRaySpeX no i did not as i was told i could use the data on it in america.
You can only use your existing data allownace whilst in US if you are on a Max Plan. Are you?
by Profile closed
Not applicable
Try turning 4G off.  All the EE branded WiFI routers EE sell only come with LTE(4G) bands 3, 7 and 20, none of which are used in the US.
3G *may* work in some areas with T-Mobile (not AT&T though) though again, it's not going to work everywhere.
I've never seen anything more than 2G when using EE branded WiFi routers in the US.  2G is of no use for data anyway.
@XRaySpeX  yes it is a max plan i have.
Ah! Good, you have all the necessary to use data in the USA.
So, it boils down to the device itself cannot run on the US mobile bands, which has been confirmed by others.
@Northerner thank you i have tried this and it works.
Hi @Debcantrill,
@Profile closed was correct, your router supports Bands 3(1800MHz), 7 (2600MHz) and 20 (800MHz) on 4G.
3G is supported on bands  1 (2100MHz), 3 (1800MHz) and 8 (900MHz).
