by Healedfeet Investigator
Mifi
My mifi box just stopped working last night. Managed to get onto my app and it said I had used up 30gb since 26th December. I hope that it's a fault with the data connection but as yet cannot check on the app or via phone. Any help as I am in Portugal and need some data connection from my mifi box to stay in touch.
Re: Mifi
Hi @Healedfeet,
Thanks for joining the EE Community.
What happens when you try to load a webpage?
Re: Mifi
Cannot even get that far. The wifi will not connect as I now can see that I have no data left but there is no way I could have use 30gb of data in 4 days. It went off when the problems started over ee a couple of days ago.
Re: Mifi
Hi @Healedfeet,
The recent problems with contacting customer services did not affect call, texts or data usage.
When you try to load a webpage are you redirected to the EE add-ons page?
Re: Mifi
hello again
the wifi mini is just telling me I have no data left and no way could I
have used 30 gb of data in 4 days. I have not tried this as on my phone it
is just saying wifi disconnected
Re: Mifi
Hi @Healedfeet,
You should still be able to connect to your WiFi device if you have used your data allowance. When connected, your web browser will automatically be redirected to the add-ons page where you can purchase more data.
What have you been using your data connection for? Data intensive tasks - such as streaming video - can use data very quickly in comparison to things like web browsing.
