29-06-2020 06:31 PM
I've lost the keep me card which had the long security network number on it and now i cant connect to the internet - does anyone know how i can find this out/make a new one?
30-06-2020 01:54 AM
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then you will be able to see your WiFi key in clear in the WiFi Settings section.
30-06-2020 01:54 AM
12-12-2020 10:39 PM
Tried the solution that you posted in June about Http://192.168.1.1, but it doesn’t seem to work anymore, any other ideas?
many Thanks
13-12-2020 07:57 AM
Hi @Prodriveress,
Welcome to the community 🙂
The password will also be on the sticker on the bottom of your router.
If this is no longer there, you can call our Customer Care Team who will be able to help.
Alex 🙂
15-12-2020 09:23 AM
I have lost my Keep Me Card which has got my security code and password on it for my mobile dongle. How can I replace it so I can set it up in my notebook?
15-12-2020 09:58 AM
@geraldine6 : Have you tried the Solution above? Doesn't it work for you?
