by Hollyh03
Is there a way I can see which devices are connected to my 4gee mifi box?Thanks
I just want to see if there’s a way to check how many users are on the WiFi box to check it is just myself using it!
Solution
Re: Is there a way I can see which devices are connected to my 4gee mifi box?Tha
Which device is it?
Yes. login to your MBB device at http://192.168.1.1 with username/pwd as "admin"/"admin" and look under Connection / Connection Status / WLAN Status / Connected Device(s) .
Solution
Which device is it?
Hi there @Hollyh03
Welcome back to the community 🙂
Did you find the information you needed following @XRaySpeX advice?
Leanne 🙂
