by zozzbozz
New Member
Incorrect password when connecting to home router
I've got the new wifi home router (white cube) and every time we try to connect to it it just says incorrect password. Any ideas appreciated.
Solution
Re: Incorrect password when connecting to home router
Hi @zozzbozz,
Welcome to the EE Community.
Are you using the password on the 'keep me' card that came with the router?
The password is case sensitive so you'll need to use capitals/lower case as appropriate.
Solution
Hi @zozzbozz,
The WiFi pwd is also to be found on the label on the box.
