by Kaz46 Investigator
I've just switchnow my Amazon firestick no longer works.
Any ideas
Re: I've just switchnow my Amazon firestick no longer works.
Hi @Kaz46
How far from the router is your fire stick?
Have you connected your fire stick it up correctly?
Hi, it's in the same room approx 3m away. I have completely reset the firestick & reconnected but nothing seems to work
@Kaz46
Quick question Is is the firestick loading up at all ?   As you say it’s not working but can you clarify what not working means.
No films etc will load. Just seems to keep whirl & not load
