by Shane2568
I am new customer, Have 4gee dongle and sim. how do I get it to work?
I have the 4GEE WIFI dongle and have just put a new nano sim into it. How do I activate it and put the £10 top up voucher on it? Also I would like to make sure I have the best internet package attached to this sim. Thanks.
Solution
Re: I am new customer, Have 4gee dongle and sim. how do I get it to work?
Text VO followed by a space and then the 16-digit voucher number to 150 from it. For example: VO 1234567891234567 .
To phone EE: The local rate landline number 0207 362 0200 or Freephone 0800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & EE TV.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC = 2014: EE 20 Meg WBC
Solution
by Shane2568
Might sound silly but how do I text from the dongle ?? I have it connected and have a top up voucher ready.
Thank you for your time. I was just hotspotting with GiffGaff but they just sent me a message saying I'm using too much data.
Most MBB routers can do SMS. Which 1 do you have?
by Shane2568
4GEE WIFI MINI
Ah, so it's not a dongle then but a router.
Browse to http://192.168.1.1 & login as "admin"/"admin". Go to the SMS section of the router.
by Shane2568
I guess so, I've just bought it from a friend who never used it and put a new sim in. Am I able to configure it and get it working without going into the store?
You should be able to. There's not much to configure. Did he not give you the Getting Started Guide?
You may undo the Solution yourself by clicking on the gearwheel Options next to it.
by Shane2568
Okay So now all I need to know is how to top up the Router using the voucher I have bought. Thanks BTW.
You send that text I told you about.
by Shane2568
If this is possible
Of course it is possible. Did you login to the router like I told you?
by Shane2568
Great success. I've managed to top up the ten pounds from my vouvher. Will this just be used at a standard rate or is there a WIFI data bundle deal I can set?
Well done!
There is no standard rate for data. You need to buy a data add-on with it. Usually data SIMs are pre-configured with a data-add-on.
  1. What does http://add-on.ee.co.uk/status report?
  2. What does texting AL to 150 report?
Recent solutions
