by sheenbeen56
I am in Europe and do I know have unlimited roaming data
As part of my contract I have limited roaming data. Because of new legislation is this now unlimited
by Brilliant Contributor
Solution
Re: I am in Europe and do I know have unlimited roaming data
Hi @sheenbeen56 If you have a plan with more than 15gb of U.K.  Data you can now use up to 15gb In the Eu each month if you have a plan with less than 15gb you can use all of it.
Also standard calls and texts as per your U.K. Allowance are included.
Hope that helps
Solution
Hope that helps
Thanks for the great answer @Damienw1
@sheenbeen56 - You can find out more in our Free EU roaming guide.
No allowance, roaming or not, has unlimited data with EE. You plan doesn't change due to the new roaming rules.
