by Fleapit Contributor
Huwawei 4G router B252
I have a 4GEE home router but with new contract I got a Huawei 4Grouter. 2 questions...
can I change the external antenna over myself or do I need to get the guy who installed it back? And is it worth switching over... are they likely to perform the same?
Solution
Re: Huwawei 4G router B252
Hi @Fleapit
I recommend having a chat with our Tech Gurus, they'll be able to check compatibility and process for you.
Hi @Fleapit
An antenna will always boost performance. If you can source one, you can install one yourself if you want.
Solution
Hi @Fleapit
I have one thanks, just wasn’t sure about installing it 😀 so that’s great thanks again
Perfect. Thanks for the tip.
Actually tried to contact them and chat doesn't give you an option to ask the question - just categories I don't fit and cant find a phone number to call for 4GEE home router customers 🙂
I find getting answers from the community so much easier than from the EE website or from trying to phone. Wish thee was an option for ' if your query does not fit any of the above phone and talk to someone and they will point you in the right direction' 🙂
but thanks 🙂
