Highlighted
Huawei 5G AF9E
Hello All,
I see EE are now offering the Huawei CPE PRO as a 5G/4G home wifi solution. I'm wondering if anyone has the Huawei 5G AF9E external antenna? If so does anyone have an idea of roughly home much cable comes with it? and if so can I buy an extension.
I currently have my router in my home office but would like to install an antenna to make the speeds just a little better.
has anyone done this?
Regards,
Highlighted
Re: Huawei 5G AF9E
Hello there @AaronUK
If you have not found the answer you needed since you posted on the community, if you contact the retailer you are purchasing this from, they will be able to help 🙂
Thanks.
Recent solutions
