by ignasius
How to remove nano sim card from 4GEE wifi mini..?
Hy Guys.., I need some help..! how to remove nano sim card from 4GEE wifi mini...??, please help me..., or have some video link maybe..?
Solution
Re: How to remove nano sim card from 4GEE wifi mini..?
Remove the coloured plastic band. With the SIM slot facing you put your fingernail in the slot at top of door & pull gently. The door should pivot open from L to R. Gently push SIM in & release. It should pop out enough to get hold of it.
Solution
by sanchezmmu
Hello, I read your answer, but I don`t understand how to remove sim. 4gee.jpg
@sanchezmmu  Push it in slightly and let go it should pop forward and you can get hold of it.
by sanchezmmu
Thanks for the quick response!
