by DavieBow Contributor
How do I get security camera to work on home router
Hi guys ,
ive just bought a home security camera system but seam to be having issues with getting it to connect to its cloud .
Im fine at home I can access the cameras via the app but once I leave the home network it just shows as being offline ......anyone have any ideas ??
17 REPLIES 17
Re: How do I get security camera to work on home router
Which home router?
It’s the 4gee one , the white one
How are you accessing it remotely? What info did you have to give it?
I have the app that came with the cameras and there was a QR code to set it up , I scanned the code and it did it’s thing and all was working well whilst on the home network , it’s only when I was away and looked to check that I noticed it didn’t work outside of the home network
Hi and welcome to the community, @DavieBow
What kind of phone do you use?
Hi
i have an iPhone X
Thanks @DavieBow
Have you tried resetting the network settings?
Settings > General > Reset > Reset network settings > follow prompts.
You may need to re-setup your WiFi connections after doing this.
On my phone ?
why do I need to do that .... just trying to get an understanding of how all this works as I don’t have a clue lol
is it not on the iPhone that you're having trouble accessing through an app, @DavieBow?
Sorry, I'm not hugely familiar with the way that CCTV systems are set up. 🙂
No it’s the actual cctv system itself that’s showing as offline on its P2P cloud .
i can access the cameras whilst on the home network but as soon as I move out of that I can’t access them
because for some reason the systems cloud setting , (which I assume must be for accessing them outside of home) isn’t transmitting our from the home hub and back up the internet to the cctv cloud service
Does the camera's manufacturer give you a website where you can login & see it from there?
its definitely something to do with with the router settings because it works when you turn DHCP off in the 4gee router ..... but then we lose all internet , turn DHCP back , internet comes back but we lose the cameras
Are you port forwarding the camera?
Not as far as I know but I’m not sure exactly what that means
Hi there @DavieBow
Have you spoken to our Tech Gurus to see what they can advise?
It’s ok I’ve sorted it ...... well one of the intelligent people at work did , they came over and did something with the ip parameters and it worked straight away
Great news @DavieBow
Thanks for coming back and letting us know 🙂
