Highlighted
by Investigator
How do I change my Mobile Wifi unit password?
How do I change my Wifi unit password?
10 REPLIES 10
Highlighted
Re: How do I change my Mobile Wifi unit password?
Hi @EEcom0163
Welcome to the community. 🙂
Which mobile router do you have?
Do you know what the original password was?
Chris​​​​​​​
Highlighted
Login to your MBB device at http://192.168.1.1 with username/pwd as "admin"/"admin". In the WiFi Settings section you can see the WiFi pwd in clear & change it.
Highlighted
by Investigator
Hi Chris
Thanks its as 4 GEE wifi MINI.   Small yellow one.
cheers Niall
Highlighted
by Investigator
Hi Chris  -For Admin Username I tried:
   admin and
tried "admin" and
tried my email address
What is my Username please?
cheers Niall
Highlighted
EE Community Team
Hi @EEcom0163,
Have you tried Username:admin and password:admin as @XRaySpeX suggested?
Do you know what your password is and want to change it to something different?
On the Osprey Mini, the network key is the last 8 digits of the IMEI number or the network key can be found on either a sticker on the battery cover or the bottom of the device.
Alex 🙂
Highlighted
You might find the admin Username & pwd by removing the battery cover, if it has 1.
Highlighted
by Investigator
@XRaySpeX no work
Highlighted
by Investigator
Yes admin does not work.
Where does Username originate?
Might it be on my package or documents?
Highlighted
by Investigator
Still not managed to hnage password or enter the system.....?
Highlighted
Thanks for confirming this has not worked @EEcom0163
I have sent you a private message for further information.
Speak soon,
Katie 🙂
