by Zoidy
Home Router coverage and connection
Using the coverage checker on this site with just the postcode (an area in Derby), no device selected, it says I will get a good 4G signal indoors. When I use the same postcode and select the 4GEE Home Router as the device, it says I will get no coverage at all. Can the 4GEE Home Router not connect to the 4G network? I have tested with a mobile phone and data sim in the area and got a great signal, but the coverage checker indicates that the 4GEE Home Router would not be able to connect to it. The product page says no fixed line needed, which indicates it uses the EE 4G mobile network. What does it connect to and why would the coverage checker indicate that specific device cannot use the strong 4G signal in that area?
Solution
Re: Home Router coverage and connection
@Zoidy : It seems that that Coverage Checker does not work for mobile BB routers, only for mobile phones. The silly thing thinks they'll get no coverage on any xG 😞 . Of course if a phone can get coverage, so can a router equally.
Solution
by Zoidy
Thanks @XRaySpeX . Yeah, it seemed to me that if a phone works then so would the router, which is why I was confused. Thanks for confirming this.
It looks like it is just a bug in the coverage map then. You never know - someone may see this and realise it is miseading people and fix it.
Hi @Zoidy and @XRaySpeX,
Thanks for bringing this issue to our attention. I've fed this back to the coverage checker team so they can investigate.
Yes, it must be a bug. EE is investigating.
Thanks! You're welcome 🙂 ! Glad I could be of assistance.
