by grima29
Help with ee 4g Home Broadband settings with 4G-N12
Can anyone help I'm having trouble with ee 30 day data sim and Asus 4G-N12, I've established a connection but speed is nothing compared to when I put the sim in my phone.
Does anyone know the settings I should set in the router? Hs anyone used this router successfully with ee?
Re: Help with ee 4g Home Broadband settings with 4G-N12
Usually you don't need to change any settings in the router from defaults, as long you haven't changed any yourself. Any speed issues will be due to external factors.
by grima29
When I put my data sim into my phone I can get 40-50 Mbits but when I put it into my router all it manages is around 2Mbits. Tested in same position with same sim card any suggestions?
I've tried switching the firewall off within the router but it didn't change the results.
Thanks in advance
Thanks for sharing this with community @grima29
Richard
