by markladson
Help! MiFi mini USB data connection
Hello everyone!
I need to use my EE MiFi mini box with my Mac Pro - the data connection must be over USB. This was working fine until I accidentally deleted the mobile broadband profile in my Network settings.
I'm lost as to how to get it back. I can add a Mobile Broadband network profile but I have no idea what settings to assign or whether this will communicate with the MiFi box. The only way I can now connect is via wifi which isn't what I need.
I REALLY appreciate any help with this.
Thank you ever so much,
Mark
Just added, it is connected via USB as I have this information from my system report:
Mobilebroadband:
  Product ID: 0x0191
  Vendor ID: 0x1bbb  (T & A Mobile Phones)
  Version: 2.42
  Serial Number: 1234567890ABCDE
  Speed: Up to 480 Mb/sec
  Manufacturer: Alcatel
  Location ID: 0xfd500000 / 2
  Current Available (mA): 500
  Current Required (mA): 500
  Extra Operating Current (mA): 0
Re: Help! MiFi mini USB data connection
I dunno how it looks from a Mac but when you remake the USB connection a notification should appear offering to run the program on it. That will create the quasi-Ethernet Network Setting.
If not you may find in the Mac's file explorer a new drive called "Web Connection" containing a Mac program you can run to do the same thing.
