by Dadisupriatna
Forget pasword my wifi
  • forgot the mini MBB wifi type code because it's missing the box
Solution
Re: Forget pasword my wifi
You should find your WiFi password on a label underneath it or found under the battery cover.
by Dadisupriatna
Solution
