by CJP_627 Contributor
Flashing blue symbols blue and will not connect.
My 4GEE WIFI MINI flashes the 4 blue symbols blue and will only connect temporarily if I remove the battery.
24 REPLIES 24
Re: Flashing blue symbols blue and will not connect.
Hi @CJP_627
Welcome to the community.
Are there any maintenance works in your area? You can check on our network status checker.
Thanks.
I had a live chat with the EE technical help and it seems that there's a fault with my device.
I've decided to end my contract. I've spent too much money for the service I've had so far.
Thanks again,
Chris.
Sorry to hear that, @CJP_627.
Did they not offer to repair the faulty device?
Yes but I had to trail back to the shop, pay to park, leave it, repeat the process to pick it up... I've paid £147 so far for about 15 hours of use. I can do without it.
Thanks.
The option is there if you change your mind, @CJP_627.
Thanks. If someone would fix it without all that hassle, I'd carry on.
On Monday, I gave technical help one more go, this time by phone. I don't want to give out a name, but if my opinion of EE has improved, it is because of the dedication of 'H'.
I was surprised at the level of flexibility that arises out of the threat to terminate the contract.
Hi @CJP_627.
Thanks for getting back to us.
I'm glad that 'H' managed to help you out and showed dedication to get your problem resolved.
Is it all working for you now?
Jon
Hi Jon_K,
Not yet. Some tests are being carried out.
Thanks.
I see @CJP_627.
Keep us updated with how you get on.
Jon
I've been busy with a house move, so I haven't used the unit for a while.
I received a replacement SIM, having been told that it would need to be activated.
My original SIM had begun to work, so I checked that first. It was okay.
Then I tried the replacement SIM (not activated at the time) and got the offending "Flashing blue symbols ...".
This led me to suppose that the symptom indicated loss of activation. I haven't had any further support since, so perhaps my theory is correct.
Is the new SIM card card activated and working now, @CJP_627?
Or are you just using the old one?
The new one hasn't been activated yet. I haven't had a response from 'H'.
I haven't tried it since that time, because of moving house etc. I'm assuming that it will work.
If not, I'll be back to square one.
Cheers.
Good Morning @CJP_627
Please keep us updated with the outcome, finger crossed this works!
Speak soon,
Katie 🙂
For a few weeks I haven't had time to do anything with the WiFi, having moved house, but it seems to have been ready to go.
I've bought a new tablet, which seems to be a Google-Monkey, that is it won't do anything without an internet connection.
So last night I tried to connect.
   It didn't work!
So that's it; I'm finished with EE.
I was aware of a colleague who'd had a nightmare when trying to get an EE land-line set up. Multiple days off work, waiting for repeat house calls. I then thought that wireless EE might be different. I now know.
Hi @CJP_627,
Did you have the same problem as last time?
Can you join the 4GEE WiFi network successfully?
Have you been able to try the device in a different location?
Hi James,
Yes, exactly the same. The location is different by about two miles. The first time it happened was before I moved house.
Thanks for confirming @CJP_627
Does the Network Status Checker show any problems in your area?
It says
"NO KNOWN PROBLEMS IN BB9***"
I think it's either the device that I've got or the SIM that's becoming de-activated. When I received a replacement SIM (to be activated later) to try out, I put it in and it did the same thing.
