by lukman92 Investigator
First time user
  • Hi, i bought my 4GEE WiFi very recently. Do i need to charge it first after i unbox it?Or can i use it right away?The seller told me to charge it first, but when i turned the device on, the batery is full, as shown by the battery indicator. Thanks.
by Ace Contributor
Re: First time user
Hi. @lukman92 If battery is full you can use it straightaway,
Many Thanks
Re: First time user
Ok thanks. :).
by Ace Contributor
Re: First time user
@lukman92 you are welcome
Re: First time user
Morning @lukman92
Glad you got the help you needed 🙂
Have a great Monday!
